Введение
This is a guide to help you remove the LCD Screen on the Sony Xperia XA2 Ultra. Review the troubleshooting page to make sure the screen is broken.
Warning: The removal of the screen could permanently damage it. Only take these steps if your current screen is broken.
Follow all available guides to make sure that the following parts have been removed:
- Sim Card Tray
- Back Cover
- Motherboard Bracket
- Rear Camera
- Front Camera
- Headphone Jack
- Motherboard
- Speaker
- Charging Port
- Vibration Motor
- Battery
Before taking any steps to open the phone, make sure that it is turned completely.
Be aware that the device will heat up when using a heat gun (or something similar). Continue with caution.
Выберете то, что вам нужно
Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
Insert a second pick once there is enough room.
Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
The iFixit opening tool may also be used to gain better leverage.
The rear cover will pop off.
Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
With your heat gun, heat the edges of the phone for about a minute. Using the iFixit opening picks, pry underneath the screen.
Take the picks and run them around the screen, removing the screen from the adhesive.
Slowly lift and remove the screen.
