Введение
If the headset mute button is not pressing down or not muting the microphone, the physical button may need to be replaced. Follow this guide to safely replace the button.
Выберете то, что вам нужно
Lift the edge of the cushion and pull out slightly.
Work your way around the cushion until it comes off completely.
Repeat for the other cushion.
Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
Flip the circuit board over and remove the keycap by pulling on it.
Desolder the wires connecting the button to the circuit board.
Desolder the three pins to remove the button from the circuit board.
For help desoldering connections, follow this useful guide on How To Solder and Desolder Connections.
Еще один человек закончил это руководство.
7 Комментариев
Where can you get the replacement switch?
I also need to know where to get the replacement switch from !
If anyone wants to try it (I have not), I think the G type switch will work. BUT you will have to find a way to mount it, as it does not have the Metal case for soldering to the PCB.
Searchebay.co.uk for 11 Types, DPDT Self Latching Locking Momentary Push Button PCB SMD Switch 6 Pin
Select Type G
Try at your own risk and good luck
