Введение
Use this guide to remove the triggers in your SteelSeries Nimbus+ controller.
Выберете то, что вам нужно
Use your fingers to remove the phone mount by pulling it straight out of the controller.
Use your fingers to remove the sticker located on the back cover of the Nimbus+.
Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
Use your fingers to lift up the mainboard from the front case.
Remove the mainboard.
Use a Phillips screwdriver to remove the four 7.0 mm screws securing the triggers on the motherboard.
Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
