Введение
Before you begin to replace the screen of your Tagital T7X be sure to review the Troubleshooting page to ensure that this is a valid solution. The screen will need to be replaced if the touch screen is not responsive or does not display anything. Some soldering is required. Good luck!
Выберете то, что вам нужно
Place the Tagital T7X on a sturdy surface.
Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
Touch the tip of the soldering iron to the solder connecting the negative wire.
Pull back on the wire with the iron in place, removing it from the hot solder.
Repeat this step for the positive wire.
Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
Remove the ribbon cable on the top left corner of the mother board.
Gently lift the black tape up to see the ribbon cable socket.
Touch the tip of the soldering iron to the solder connecting the positive (red) wire.
Repeat this step for the negative wire.
Use a spudger to hold the cameras in place.
Gently pull the black tape away using your finger.
Remove the ribbon cable from the motherboard.
Use a spudger to lift the two tabs, freeing the ribbon cable from the socket.
Next we will disconnect the digitizer ribbon cable from the motherboard.
Using the black spudger, gently push the tabs on each side of the socket to free the ribbon cable.
Next, we will unscrew the three PH#0 screws anchoring the motherboard into the case.
Using the screwdriver, with the PH#0 attachment, carefully unscrew the screws of the motherboard in order to remove it from the device.
Insert a plastic opening tool where the screen connects with the front face of the case.
2 участников успешно повторили данное руководство.
