Testing Power Cord Continuity
Выберете то, что вам нужно
  1. Testing Power Cord Continuity, Set the multimeter to continuity test mode: шаг 1, изображение 1 из 2 Testing Power Cord Continuity, Set the multimeter to continuity test mode: шаг 1, изображение 2 из 2
    • Unplug the power cord from the device and from the AC outlet. Failure to do so can result in electrical shock or death.
    • Set the multimeter to continuity test mode.
    • The setting is symbolized by a diode or sound wave symbol as seen in the pictures. If the meter is set to the correct mode, you should hear the meter beep when the leads are touched together.
    • Verify that the positive lead is plugged to the voltmeter/ ohmmeter outlet.
  2. Testing Power Cord Continuity, Test for a break in the cable: шаг 2, изображение 1 из 1
    • Test for a potential open circuit by using one multimeter lead to touch one of the prongs on the AC side of power cord. Use the other lead to touch one end of the console side of the power cord.
    • If there is an adequate electrical connection, the multimeter will continuously beep. A short beep does not mean that there is continuity. If it does not beep the first time, try using the lead to touch the other prong.
    • Repeat the above directions in step 2 for the other outlet and prong of the power cord.
    • If the multimeter fails to beep on any of the occasions outlined above, your power cord is open. In other words, you will need to replace the power cable.
  3. Testing Power Cord Continuity, Test for a short: шаг 3, изображение 1 из 1
    • Once you have verified that the power cord provides an adequate electrical connection, you will have to test that the cable is not shorted.
    • Test for a potential short circuit by touching each prong on the AC side of the power cord.
    • If the multimeter beeps, your power cord is bad and must be replaced immediately.
    • If your power cord is shorted, do not attempt to replug the cord into the AC outlet.
    • If your power cord has passed all of the steps above, then you have successfully tested that your power cord is in working order.
Финишная прямая
161 человек успешно провели ремонт по этому руководству.
Darren Chan
Участник с: 10/28/09
5 388 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 5-1, Regan Fall 2009 Участник Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 членов
Автор 23 руководств
16 Комментарии к руководству
Thank you very much.
Kaky Jerry - Ответить Поделиться
Wow Wow Just a Great Guide, Now I have learned one more skill :)
Muhammad Imran - Ответить Поделиться
Brilliant love it
Liam Breen - Ответить Поделиться
Worked like a charm I feelik an electrician
hadpaulkh - Ответить Поделиться
I found this really wonderful and useful with details explained very well. I was always wondering what the electricians do with a multimeter. Now iI would buy one multimeter and do this on my own. Great and cool guide. Write more guides for other tests and verification.
Avinash S - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 37
За последние 7 дней: 237
За последние 30 дней: 2,076
За всё время: 280,576
