Texas Instruments TI-80 Button Replacement
Выберете то, что вам нужно
  1. Texas Instruments TI-80 Button Replacement, Batteries: шаг 1, изображение 1 из 1
    • Locate battery cover on the back of the case.
    • Slide battery cover to the right reveal the batteries.
    Спросите у FixBot
  2. Texas Instruments TI-80 Button Replacement: шаг 2, изображение 1 из 1
    • Remove battery cover.
    • Slide the red lock down.
    • Slide the metal tab to the right of the top battery.
    • Remove the 3-Volt Lithium Coin Cell Battery.
    • Slide the red lock up.
    • Slide the metal tab to the right of the bottom battery.
    Спросите у FixBot
  3. Texas Instruments TI-80 Button Replacement, Back Case: шаг 3, изображение 1 из 3 Texas Instruments TI-80 Button Replacement, Back Case: шаг 3, изображение 2 из 3 Texas Instruments TI-80 Button Replacement, Back Case: шаг 3, изображение 3 из 3
    • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
    • Unscrew four 7.15 mm screws from back casing.
    • Using the blue plastic opener tool along the seam of the case, pry off front casing.
    • Start prying from the bottom of the calculator as the casing hooks into the top.
    Спросите у FixBot
  4. Texas Instruments TI-80 Button Replacement, Motherboard and Screen: шаг 4, изображение 1 из 2 Texas Instruments TI-80 Button Replacement, Motherboard and Screen: шаг 4, изображение 2 из 2
    • Using a Philips PH0 screwdriver, remove the 6 screws. 2 from the top of the Motherboard, 2 from the middle, and 2 from the bottom of the Motherboard.
    • Using a Phillips Ph0 screwdriver, remove 4 screws from the screen mount.
    • Using the blue plastic opening tool, pry the Motherboard up.
    • Using the blue plastic opening tool, pry up the screen from the screen mount.
    Спросите у FixBot
  5. Texas Instruments TI-80 Button Replacement, Check keyboard mat: шаг 5, изображение 1 из 2 Texas Instruments TI-80 Button Replacement, Check keyboard mat: шаг 5, изображение 2 из 2
    • Check the rubber mat for damage or obstruction at the location of non-functioning buttons.
    • Flip the mat over to assess dirt and damage.
    • Replace the mat if it is damaged.
    • Clean off the back of the Motherboard as necessary. The mat lies on top, so dirt and debris may build up. Repeat cleaning as needed.
    Спросите у FixBot
  6. Texas Instruments TI-80 Button Replacement, Check Buttons: шаг 6, изображение 1 из 1
    • Check the back of the buttons for damage or obstructions.
    • If obstructions are present, clear them.
    • Do not tilt the calculator, or buttons may fall out.
    Спросите у FixBot
  7. Texas Instruments TI-80 Button Replacement, Replace Buttons: шаг 7, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • If a button is damaged, use tweezers to lift the button out of the facing.
    Спросите у FixBot
  8. Texas Instruments TI-80 Button Replacement, Insert new Buttons: шаг 8, изображение 1 из 1
    • Insert new button, making sure that it is positioned properly.
    • For all buttons, there is an extrusion in the upper left quadrant when looking at the back of the key. These should be aligned with the top of the calculator.
    Спросите у FixBot
Заключение
Calvin
Участник с: 01/08/15
201 Репутация
Автор 2 руководств
Команда
Eastern Washington University, Team 1-1, Carnegie Winter 2015 Участник Eastern Washington University, Team 1-1, Carnegie Winter 2015
EWU-CARNEGIE-W15S1G1
4 членов
Автор 8 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 77
За всё время: 742
