The Claw Circuit Board Replacement
Выберете то, что вам нужно
  1. The Claw Circuit Board Replacement, Bottom Cover: шаг 1, изображение 1 из 1
    • Place The Claw in upright position with controls facing you.
  2. The Claw Circuit Board Replacement: шаг 2, изображение 1 из 1
    • Gently flip The Claw machine upside down with the controls facing you.
  3. The Claw Circuit Board Replacement: шаг 3, изображение 1 из 1
    • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
    • You will need a screwdriver with a long thin neck to fit in the screw holes.
  4. The Claw Circuit Board Replacement: шаг 4, изображение 1 из 2 The Claw Circuit Board Replacement: шаг 4, изображение 2 из 2
    • Slide the bottom cover off to the side.
    • Do not completely remove bottom cover as it is still connected to wires.
  5. The Claw Circuit Board Replacement: шаг 5, изображение 1 из 1
    • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
    • You will need to cut the two green wires attached to the music player.
    • Then you will need to cut the white wire that leads to the battery compartment.
    • Finally you will need to cut the black wire leading to the battery compartment as well.
    • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: How To Solder and Desolder Connections.
  6. The Claw Circuit Board Replacement, Circuit Board: шаг 6, изображение 1 из 1
    • Once you have removed the bottom cover you should have clear access to the circuit board.
    • Locate the circuit board in the bottom of The Claw machine.
  7. The Claw Circuit Board Replacement: шаг 7, изображение 1 из 1
    • Locate the screws that hold the circuit board in place.
  8. The Claw Circuit Board Replacement: шаг 8, изображение 1 из 1
    • Be sure to turn off the device and remove the batteries before reaching into the device with your hands or any metal tools.
    • Using a Phillips #1 screwdriver, remove the four 6mm that hold the circuit board in place.
    • You will also need to cut all of the wires leading to the circuit board to completely remove it.
  9. The Claw Circuit Board Replacement: шаг 9, изображение 1 из 1
    • Remove the circuit board.
    • The removal of the circuit board requires the cutting of existing wires and soldering new wires to the new board. For help with soldering reference: How To Solder and Desolder Connections.
Заключение
2 участников успешно повторили данное руководство.
Alain Pierre
Участник с: 03/22/16
1 188 Репутация
Автор 9 руководств
Команда
UMass Dartmouth, Team 4-8, Catania Spring 2016 Участник UMass Dartmouth, Team 4-8, Catania Spring 2016
UMASSD-CATANIA-S16S4G8
3 членов
Автор 18 руководств
6 Комментариев
I accidentally cut the wires where the motors are and now can not figure out which go where, is there a diagram or drawling of where each wire goes?
Dyn4mic Universe - Ответить
Did you ever find a diagram for this? I would like to have one also….
Nathan Riffel -
Does anybody know where to get the replacement switches for these?
Bill B. - Ответить
Same. I am in need of the replacements as well.
Allison Rousseau -
Me too. L/R switch doesn't work need to replace it.
Johnny Annon -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 42
За последние 30 дней: 83
За всё время: 5,971
