Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the battery from the system. To do this, push the locking tab into the unlocked position.
Once the battery is unlocked, hold the locking tab in and push the battery out.
To remove the bottom memory module, open the memory door. Use a Phillps #0 screwdriver.
With the bottom RAM door removed, release the bottom memory module. Release both locking tabs and the module can be removed.
To access the memory module under the keyboard, remove the silver screw securing the keyboard.
To remove the keyboard, push up from the bottom first. Once the lower tabs are released, use a plastic pry tool to lift the keyboard up.
Once the keyboard is removed, disconnect the cable from the motherboard. Use a plastic pry tool.
To remove the RAM module, follow the removal procedure from the bottom lower module.
To reinstall the keyboard, push the top of the keyboard in first. Once the top is pushed in, slide the keyboard down to secure it. Screw the keyboard back in.
11 участников успешно повторили данное руководство.
