Введение
This guide shows how to remove and replace the driveshaft for the Toro Cement Mixer 68009HD. In order to access the driveshaft, you must first remove the tub.
Warning: The tub is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
Выберете то, что вам нужно
Before you begin, press the engine-stop switch to turn off the engine.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Remove the four fasteners securing the engine plate:
Two 14 mm bolts
Two 3/4 inch nuts
Use a 3/4 inch wrench to loosen the four bolts securing the engine to the frame.
Use a crescent wrench to loosen the two set screws on the pulley.
Reassembly tip: The pulley is keyed to install in only one position.
Use a 4 mm hex key to loosen the set screw securing the lock collar.
There should only be one set screw. If the collar isn't loose, check the second hole for set screws.
Use a screwdriver to pry and loosen the lock collar from the shaft.
Slide the lock collar off the shaft and remove it.
