Введение
This guide shows how to remove and replace the two drivetrain V-belts for the Toro Cement Mixer 68009HD.
Выберете то, что вам нужно
Before you begin, press the engine-stop switch to turn off the engine.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Remove the four fasteners securing the engine plate:
Two 14 mm bolts
Two 3/4 inch nuts
Use a 3/4 inch wrench to loosen the four bolts securing the engine to the frame.
