Введение
Replacing the optical drive in a Toshiba Satellite laptop should not be seen as difficult, but does involve opening one of the panels on the underside of the laptop.
Выберете то, что вам нужно
Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
Place laptop with the bottom of it facing up.
Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
3 человек успешно провели ремонт по этому руководству.
Один комментарий
Any idea of how tall the drive is? Is it 12.7mm or 9.5mm tall?
