Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your keyboard is damaged or not working properly, it is fairly easy to replace.
Выберете то, что вам нужно
Close the laptop lid and flip the laptop over.
Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
Push the release button to the right.
Hold the release button to the right and lift the battery out of its housing.
Open the laptop so the keyboard is facing you and the locate the thin plastic cover located directly above the keyboard.
Using your fingers, remove this long piece of plastic gently.
Remove the two 4.8 mm type-0 Phillips head screws located underneath the plastic cover piece.
Starting at the top, gently raise the keyboard enough to remove it from the socket.
Locate the data cable that is connected to the motherboard.
Pull the white ZIF connector towards the screen to remove it.
Pull the black ribbon cable away from the screen.
With the black ribbon cable now disconnected, remove the keyboard from its housing.
Congratulations, you have removed the laptops original keyboard and can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order with the new keyboard.
3 участников успешно повторили данное руководство.
