Toshiba Satellite L55W-C5256 CPU Heatsink Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement, Battery: шаг 1, изображение 1 из 1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: шаг 2, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: шаг 3, изображение 1 из 1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: шаг 4, изображение 1 из 1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: шаг 5, изображение 1 из 1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: шаг 6, изображение 1 из 1
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement, CPU Heatsink: шаг 7, изображение 1 из 1
    • Using a Phillips #00 screw driver, remove the four 7.0 mm screws that secure the heat sink to the CPU.
  8. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: шаг 8, изображение 1 из 1
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the heat sink fan to the motherboard.
  9. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: шаг 9, изображение 1 из 3 Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: шаг 9, изображение 2 из 3 Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: шаг 9, изображение 3 из 3
    • Before you touch any component inside your device, ensure you are properly grounded with an anti-static band.
    • Gently lift the heat sink from the motherboard, making sure not to apply much tension to the connector cable.
    • Using your thumb and forefinger, gently unplug the connector cable from the motherboard.
    • Lift the heat sink from the motherboard.
    • If you need to replace the heat sink, check out this thermal paste guide that will walk you through the steps necessary to replace the thermal compound.
Заключение
Еще один человек закончил это руководство.
Jennifer
Участник с: 09/23/19
777 Репутация
Автор 5 руководств
Команда
Western Carolina University, Team S1-G5, Virtue Fall 2019 Участник Western Carolina University, Team S1-G5, Virtue Fall 2019
WCU-VIRTUE-F19S1G5
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 183
