Toshiba Satellite L55W-C5256 Speaker Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite L55W-C5256 Speaker Replacement, Battery: шаг 1, изображение 1 из 1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 2, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 3, изображение 1 из 1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 4, изображение 1 из 1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 5, изображение 1 из 1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 6, изображение 1 из 1
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 Speaker Replacement, CPU Heatsink: шаг 7, изображение 1 из 1
    • Using a Phillips #00 screw driver, remove the four 7.0 mm screws that secure the heat sink to the CPU.
  8. Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 8, изображение 1 из 1
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the heat sink fan to the motherboard.
  9. Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 9, изображение 1 из 3 Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 9, изображение 2 из 3 Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 9, изображение 3 из 3
    • Before you touch any component inside your device, ensure you are properly grounded with an anti-static band.
    • Gently lift the heat sink from the motherboard, making sure not to apply much tension to the connector cable.
    • Using your thumb and forefinger, gently unplug the connector cable from the motherboard.
    • Lift the heat sink from the motherboard.
    • If you need to replace the heat sink, check out this thermal paste guide that will walk you through the steps necessary to replace the thermal compound.
  10. Toshiba Satellite L55W-C5256 Speaker Replacement, Speakers: шаг 10, изображение 1 из 2 Toshiba Satellite L55W-C5256 Speaker Replacement, Speakers: шаг 10, изображение 2 из 2
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the left speaker to the motherboard.
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the right speaker to the motherboard.
  11. Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 11, изображение 1 из 2 Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 11, изображение 2 из 2
    • Before touching any component inside your device, ensure you are properly grounded with a static band.
    • Gently unplug the speaker connector cable from the motherboard.
  12. Toshiba Satellite L55W-C5256 Speaker Replacement: шаг 12, изображение 1 из 1
    • Lift speakers from motherboard.
Заключение
Еще один человек закончил это руководство.
Jennifer
Участник с: 09/23/19
777 Репутация
Автор 5 руководств
Команда
Western Carolina University, Team S1-G5, Virtue Fall 2019 Участник Western Carolina University, Team S1-G5, Virtue Fall 2019
WCU-VIRTUE-F19S1G5
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 153
