Введение
This guide will instruct you on how to safely remove and replace the speakers of your Toshiba Satellite L55W-C5256. You may need to do this if:
- Your device’s speakers are “blown”, or are emitting crackling noises
- Your device is not outputting any audio
Before beginning this replacement guide, it is recommended that you use an anti-static work mat and that you ground yourself using an anti-static wrist strap. This helps to protect your device from damage caused by static discharge. If you do not have these materials, you can find an anti-static wrist strap here, and an anti-static work mat here. To learn how to properly use an anti-static wrist strap and an anti-static work mat (recommended), see the guide found here.
Выберете то, что вам нужно
Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
Using a Phillips #00 screw driver, remove the four 7.0 mm screws that secure the heat sink to the CPU.
Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the heat sink fan to the motherboard.
Gently lift the heat sink from the motherboard, making sure not to apply much tension to the connector cable.
Using your thumb and forefinger, gently unplug the connector cable from the motherboard.
Lift the heat sink from the motherboard.
Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the left speaker to the motherboard.
Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the right speaker to the motherboard.
Еще один человек закончил это руководство.
