Toshiba Satellite L755D-S5150 Motherboard Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Motherboard Replacement, Keyboard: шаг 2, изображение 1 из 1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 3, изображение 1 из 1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: шаг 5, изображение 1 из 2 Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: шаг 5, изображение 2 из 2
    • Using the Phillips PH00 screwdriver remove the three 4mm screws from the cover for the RAM.
    • Use the Phillips PH00 to remove the one 4mm screw that holds the ODD.
    • Slide the ODD outward.
    • Removing the RAM is not necessary
    • The ODD is also commonly referred to as a CD-ROM.
  6. Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 6, изображение 1 из 1
    • Use the Phillips PH00 screwdriver to remove one 4mm screw.
    • Use the Phillips PH00 screwdriver to remove the two 3mm screws from the fan.
    • The motherboard will be accessed from below the keyboard, therefore you will not need to take out the bottom of the laptop.
  7. Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 7, изображение 1 из 1
    • Use the Phillips PH00 to unscrew the fifteen 4mm screws holding down the motherboard.
  8. Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 8, изображение 1 из 2 Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 8, изображение 2 из 2
    • Lift the motherboard and disconnect the 4 pin connector on the bottom side.
Заключение
2 человек успешно провели ремонт по этому руководству.
Shaheedah
Участник с: 10/06/16
276 Репутация
Автор 2 руководств
Команду
USF Tampa, Team 2-5, Sullivan Fall 2016 Участник USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 членов
Автор 5 руководств
Один комментарий
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 1,087
