Trio Stealth-G4X Camera Replacement
Выберете то, что вам нужно
  1. Trio Stealth-G4X Camera Replacement, Camera: шаг 1, изображение 1 из 1
    • Starting near the middle edge of the Trio Stealth-G4X tablet, gently work an opening pick or spudger in between the seams of one side of the tablet.
  2. Trio Stealth-G4X Camera Replacement: шаг 2, изображение 1 из 1
    • Work your way around all four corners of the tablet, unlocking all of the retaining tabs that hold the tablet together. This will allow you to separate the two halves of the tablet and access the motherboard.
    • Be sure not to over penetrate while separating the two halves as you may damage the tablet's internal hardware.
  3. Trio Stealth-G4X Camera Replacement: шаг 3, изображение 1 из 1
    • Once the two halves are separated, set aside the back cover of the tablet as you will not need it until reassembly. Now locate the camera on the motherboard of the tablet.
  4. Trio Stealth-G4X Camera Replacement: шаг 4, изображение 1 из 1
    • Peel back the yellow protective film on the motherboard to access the camera's ribbon cable.
  5. Trio Stealth-G4X Camera Replacement: шаг 5, изображение 1 из 1
    • Take the Phillips head screwdriver and unscrew the 3mm screw right above the camera assembly. Place the screw aside so you do not lose it.
  6. Trio Stealth-G4X Camera Replacement: шаг 6, изображение 1 из 1
    • Use a spudger to pry the black tab on this connection point upwards. This will unlock the ribbon cable that connects the camera to the motherboard.
    • Once unlocked, very carefully pull the cable out of the socket to disconnect it.
    • Be very delicate with the ribbon cable because it can tear easily.
  7. Trio Stealth-G4X Camera Replacement: шаг 7, изображение 1 из 1
    • Now you can remove the camera assembly. Use a spudger to gently loosen the camera out of place.
  8. Trio Stealth-G4X Camera Replacement: шаг 8, изображение 1 из 1
    • Grab the camera assembly with your fingers and gently lift it out of the tablet.
  9. Trio Stealth-G4X Camera Replacement: шаг 9, изображение 1 из 1
    • You have now removed the camera assembly and can set it aside. Insert replacement camera by following the steps in reverse. Then reassemble the tablet the same way.
Заключение
Emily Dorsey
Участник с: 08/26/15
434 Репутация
Автор 4 руководств
Команда
Western Carolina University, Team 1-3, Virtue Fall 2015 Участник Western Carolina University, Team 1-3, Virtue Fall 2015
WCU-VIRTUE-F15S1G3
4 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 162
