Выберете то, что вам нужно
Begin by flipping over the transmitter, and removing the padding from the underside of it. This will reveal the screws to take apart the device.
Remove the screws ( 11.27mm Phillips head) and open up the transmitter to reveal the internal components. Carefully pry open the transmitter, and use caution when opening it up as to not sever the wire.
Remove the two screws (5.21mm Phillips head) on the board on the top half of the transmitter that is holding the charging pins.
Once the screws are removed, desolder the two wires from the board, and then remove it, and the charging pins with it.
