Using the 3DS's Safe Mode
  1. Using the 3DS's Safe Mode, Booting safe mode: шаг 1, изображение 1 из 1
    • Ensure the console is powered off
    • Hold the (L) + (R) + (A) + (D-Pad Up) buttons
    • Keep these buttons held down until the console boots in the next step
    • While still holding the other buttons, press the power button
    Спросите у FixBot
    Добавить комментарий
  2. Using the 3DS's Safe Mode, Updating the System: шаг 2, изображение 1 из 3 Using the 3DS's Safe Mode, Updating the System: шаг 2, изображение 2 из 3 Using the 3DS's Safe Mode, Updating the System: шаг 2, изображение 3 из 3
    • You should boot into a "system update" screen. Click OK and accept the prompts
    • If there's no working internet connection configured on your 3ds, you'll have the option to set one up now
    Спросите у FixBot
  3. Using the 3DS's Safe Mode: шаг 3, изображение 1 из 1
    • When the update finishes, the console will automatically turn off
    Спросите у FixBot
Заключение
If your issue persists after following this guide, a system format may fix it. Or, if you'd prefer to keep your data, you can ask a question
3 человек успешно провели ремонт по этому руководству.
darth mango
Участник с: 03/13/23
3 745 Репутация
Автор 3 руководств
4 Комментарии к руководству
Does this work on old family 3ds?
maxxy waxxy - Ответить Поделиться
Works on every 3ds and 2ds model
darth mango - Ответить Поделиться
Hello Darth mango. I have had my 3ds xl (red btw) since 2016. It stopped working in 19 and I gave up. Never knew why, but when I tried this it didn't work. I see u have a reputation for fixing this stuff and I followed EVERY one of our guides. Nothing works. Should I just just go get it repaired, because NOTHING will work, even this.
Jahasen :D - Ответить Поделиться
Can you post a question about this? I try to avoid troubleshooting in comments as opposed to the forum made for it. Remember to include any symptoms (what happens when you plug it in, try to turn it on, etc.) as well as what fixes you've already tried. The better the info you give us, the better we'll be able to help. :D
Статистика просмотров:
За последние 24 часов: 18
За последние 7 дней: 107
За последние 30 дней: 466
За всё время: 15,471
