V-Moda Crossfade Wireless Headphones Battery Replacement
Выберете то, что вам нужно
  1. V-Moda Crossfade Wireless Headphones Battery Replacement, Battery: шаг 1, изображение 1 из 3 V-Moda Crossfade Wireless Headphones Battery Replacement, Battery: шаг 1, изображение 2 из 3 V-Moda Crossfade Wireless Headphones Battery Replacement, Battery: шаг 1, изображение 3 из 3
    • The battery is housed in the left half of the headphones (the side with the micro-USB port).
    • Grasp the left ear cup cushion with your fingers and gently pull towards the center of the earcup. This will release the cushion from the tabs that are holding it in place.
    • Gently pull the ear cup from the rest of the tabs that hold it in place.
    • Remove the ear cup cushion.
    • To reinstall the cushion, align the ear up to the headphones. Squeeze around the perimeter of the cushions to snap the ear cup in place.
  2. V-Moda Crossfade Wireless Headphones Battery Replacement: шаг 2, изображение 1 из 2 V-Moda Crossfade Wireless Headphones Battery Replacement: шаг 2, изображение 2 из 2
    • Remove the six 10.1 mm Phillips screws securing the left headphone's speaker plate.
    • Insert an opening pick in the seam between the left headphone's plastic housing and metal rim.
    • Slide the pick along the seam and twist gently to loosen the speaker plate.
  3. V-Moda Crossfade Wireless Headphones Battery Replacement: шаг 3, изображение 1 из 2 V-Moda Crossfade Wireless Headphones Battery Replacement: шаг 3, изображение 2 из 2
    • Grasp the metal rim with your fingers and gently pull it away from the headphone cup.
    • Do not attempt to remove the speaker plate. The speaker is connected with very delicate wires.
  4. V-Moda Crossfade Wireless Headphones Battery Replacement: шаг 4, изображение 1 из 2 V-Moda Crossfade Wireless Headphones Battery Replacement: шаг 4, изображение 2 из 2
    • As you work on the headphones, be careful not to stress the delicate speaker cable.
    • The battery is a Kanyo 350 mAh pack measuring 34mm x 24mm x 5mm.
    • The battery area can fit a battery that's up to 39.4mm x 31mm x 5mm.
    • There are reports that V-Moda has been using different sized battery packs. Before you order a replacement battery, be sure to measure carefully.
    • You can replace the battery with any standard two-wire lithium-ion polymer pack that would fit in the space.
  5. V-Moda Crossfade Wireless Headphones Battery Replacement: шаг 5, изображение 1 из 2 V-Moda Crossfade Wireless Headphones Battery Replacement: шаг 5, изображение 2 из 2
    • Remove the two 5.9 mm Phillips screws securing the micro-USB port.
    • Use the flat end of a spudger to pry up and loosen the board from the two screw posts.
  6. V-Moda Crossfade Wireless Headphones Battery Replacement: шаг 6, изображение 1 из 2 V-Moda Crossfade Wireless Headphones Battery Replacement: шаг 6, изображение 2 из 2
    • Carefully flip the board over and note the two solder joints connected to the battery cables.
    • De-solder the two solder joints and replace the battery. You will have to re-solder the battery to these contact points.
    • Alternatively, cut the wires one-by-one before you desolder them. This will help prevent unintentional short circuitry.
    • Be very careful not to short the battery wires. Doing so may overheat and ignite the battery.
    • Be sure to maintain the correct battery polarity when you re-solder the wires.
    • The back of the board is shown for reference.
Заключение
9 участников успешно повторили данное руководство.
Arthur Shi
Участник с: 01/03/18
253 248 Репутация
Автор 526 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 139 руководств
14 Комментариев
any link to get the right battery Mr. Arthur?
florescristobal14 - Ответить
I have not tried it, but a li-po pack like this should work, while even giving you a battery capacity boost. Again, you would need to solder the battery contacts on.
Arthur Shi -
Hey just finished completing my battery replacement with flying colors thx for the guide and link to the replacement battery my man.
Squeezy Jibbs - Ответить
I’m glad to hear it worked out for you!
Arthur Shi -
I need to clean the underside of the grill that’s over the speaker… Is there any way to remove the grill without damaging it??
Gabriel - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 41
За последние 30 дней: 214
За всё время: 12,630
