Введение
During this guide, the base will need to be disassembled and then desolder the charging wire connections.
Выберете то, что вам нужно
Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
Refer to How to Solder and Desolder connections How To Solder and Desolder Connections
Take a wire of solder and apply to joint on board to remove the extra solder.
Note: Ensure the old solder joint is removed.
Caution: Soldering iron and joint will become very hot.
Remove charging wire connection.
Еще один человек закончил это руководство.
