Введение
Are you unable to adjust the volume? This guide may help solve your problem.
Выберете то, что вам нужно
To remove the battery door, loosen the screw using a Flathead screwdriver.
Remove the six 9.5 mm Phillips #2 screws.
Remove the six 6.0 mm Phillips #2 screws.
Gently pull up on the rear panel.
Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
Using a Phillips PH1 screwdriver, remove the two 7.9 mm volume switch board screws.
Заключение
