Введение
This guide will show you how to replace a cracked or malfunctioning display for your Velocity Micro Tablet T301.
The display, or screen, of the tablet may need to be replaced if the glass cracks or is broken as this can affect its touch screen capabilities. A cracked or broken screen can also potentially lead to injuries. You may also need to replace the display if the light-emitting pixels powering the display are beginning to dim or malfunction, leading to uneven lighting and color.
Be sure to completely power off your tablet and disconnect it from any external power sources before beginning this guide. If your display is shattered, follow this guide to avoid injury while replacing the display. Finally, make sure to acquire the necessary tools listed in the "What you need" section of this guide.
Выберете то, что вам нужно
Insert the larger plastic opening tool in the SD port. The edge point should be pointed towards the rear panel.
The large opening tool can now be removed, leaving only the small opening tool in place.
Slide the small opening tool along the seam of the rear panel to fully remove it.
Using a plastic spudger, disconnect the wire attaching the battery to the tablet.
Slide the spudger around the tablet to release the clips attached to the screen, thus detaching the back and revealing the motherboard.
Use a plastic spudger to disconnect the wires between the speakers and the motherboard as shown in the picture.
