Введение
If the power button on your Vivitar Vivicam T027 digital camera breaks or gets jammed, you may need to replace it. This guide will show you how.
Note: This repair requires soldering. View the soldering guide for more information.
Выберете то, что вам нужно
Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
You will find one screw on the top, one on the bottom, and one on each side of the camera.
Remove the sticker on the top of the camera.
Use the Phillips #00 screwdriver to remove the screw that was underneath the sticker.
Separate the front and the back of the camera completely to expose the motherboard.
Using a soldering kit, de-solder the black and red wire from the silver power button.
Solder the new power button to the black and red wire.
