Vtech Kidizoom Smart Watch DX Battery Replacement
Выберете то, что вам нужно
  1. Vtech Kidizoom Smart Watch DX Battery Replacement, Master Switch: шаг 1, изображение 1 из 1
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Battery Replacement: шаг 2, изображение 1 из 1
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Battery Replacement: шаг 3, изображение 1 из 1
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Battery Replacement: шаг 4, изображение 1 из 2 Vtech Kidizoom Smart Watch DX Battery Replacement: шаг 4, изображение 2 из 2
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: шаг 5, изображение 1 из 2 Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: шаг 5, изображение 2 из 2
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Battery Replacement: шаг 6, изображение 1 из 1
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Battery Replacement: шаг 7, изображение 1 из 1
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Battery Replacement: шаг 8, изображение 1 из 1
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Battery Replacement: шаг 9, изображение 1 из 1
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: шаг 10, изображение 1 из 2 Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: шаг 10, изображение 2 из 2
    • Using the plastic opening tool, gently pry the edges of the battery away from from the circuit board.
    • There is a thin layer of adhesive holding the battery to the circuit board. This will remain sticky after prying.
  11. Vtech Kidizoom Smart Watch DX Battery Replacement: шаг 11, изображение 1 из 1
    • De-solder the red battery wire from the circuit board.
  12. Vtech Kidizoom Smart Watch DX Battery Replacement: шаг 12, изображение 1 из 1
    • Repeat the de-soldering for the black (ground) wire.
  13. Vtech Kidizoom Smart Watch DX Battery Replacement: шаг 13, изображение 1 из 1
    • Pull the battery free, and wait for the solder to cool before handling further.
Заключение
4 участников успешно повторили данное руководство.
Navin Ramkishun
Участник с: 01/20/16
259 Репутация
1 руководство автора
Команда
USF Tampa, Team 10-6, Remmell Spring 2016 Участник USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 членов
Автор 12 руководств
Один комментарий
Where did you bought the battery?
funkysoulbrother - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 43
За всё время: 8,986
