Vtech Kidizoom Smart Watch DX Circuit Board Replacement
Выберете то, что вам нужно
  1. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Master Switch: шаг 1, изображение 1 из 1
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: шаг 2, изображение 1 из 1
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: шаг 3, изображение 1 из 1
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: шаг 4, изображение 1 из 2 Vtech Kidizoom Smart Watch DX Circuit Board Replacement: шаг 4, изображение 2 из 2
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: шаг 5, изображение 1 из 2 Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: шаг 5, изображение 2 из 2
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: шаг 6, изображение 1 из 1
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: шаг 7, изображение 1 из 1
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: шаг 8, изображение 1 из 1
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: шаг 9, изображение 1 из 1
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
Заключение
7 участников успешно повторили данное руководство.
Jordan RiberSmith
Участник с: 01/20/16
755 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 10-6, Remmell Spring 2016 Участник USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 членов
Автор 12 руководств
2 Комментариев
Where can I buy the circuit board ?? Please send me a link or just post it please. Thanks
Jamar Mckay - Ответить
Where can I buy replacement and how much should it cost?
Marisol Pelayo - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 19
За последние 30 дней: 73
За всё время: 9,809
