Введение
Use this guide to replace the main board a.k.a. Cycle Control Unit (CCU) on your Whirlpool WED87HED Dryer.
The main board is the "brain" of the dryer. When it fails, the dryer will operate erratically or not operate at all.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:FixMat$36.95
Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
Lift the top panel upward to separate it from the chassis.
Remove the top panel from the machine.
Using a flat head screwdriver or a spudger, release the cover clips.
Lift the cover to release the tabs on the opposite side of the main board housing.
Remove the cover.
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Lift the board with one hand and use the other to release each clip with a spudger.
Release the remaining clips until the board is completely separated from its housing.
Repair didn’t go as planned? Ask our Answers community for help.
