Введение
In this simple and straightforward guide we will show you how to disassemble and replace the joystick and buttons of a Wii Nunchuk controller. You may need to replace the buttons and joystick if they stop working or you may just want to give the area a good careful clean with isopropyl alcohol.
Выберете то, что вам нужно
Use a Tri-point Y0 screwdriver to remove the two 9.2 mm screws from the back of the controller.
Take the motherboard by the edges, and gently lift it out of the shell, exposing the buttons.
Set the motherboard to the side so that it is out of the way.
Push the buttons in from the outside of the device to pop them out.
Set the new buttons into the cutouts of the controller shell, ensuring they sit flush inside the controller.
Place the top case of the controller on the bottom shell, making sure to align the halves properly.
Push them together until you hear a small click, ensuring the controller is assembled securely.
Use a Tri-point Y0 screwdriver to replace the two 9.2 mm screws that secure the back case.
