Введение
The WowWee MiP robot has a tendency towards short battery life. If the MiP seems too slow or stops responding, use this guide to change the MiP’s batteries. The MiP’s batteries are located in a battery pack on the robot's back.
Выберете то, что вам нужно
Carefully pull the battery pack from the robot.
Remove the batteries from the battery pack.
3 человек успешно провели ремонт по этому руководству.
14Комментарии к руководству
Its a programmer MIP not this kind.
Same question here, instructions needed for CODER MIP as it doesn't seem to be a holding a charge.
does spare battery adapter vailable(not reachargeable)
Same CODER MIP here - we got erratic performance from the battery pack. A smart slap seems required to ensure a tight battery connection after a robot fall, otherwise it appears to have run out of battery. Not optimal, but it allowed us to play for a while.
My Mip doesn’t work even if I replace the batteries. It acts very strange. It keeps making a clicking noise
Mine does to
I have A Coder MiP instead of a plain MiP
Are there different instructions.
