Введение
This guide will involve the replacement of the motor that drives the X-Street SRT Viper. Reinstalling the motor will require you to re-solder the wires back on. This guide is slightly more difficult than the other guides. Follow and reach each step carefully.
Click here to purchase a replacement motor. Replacement Motor
Выберете то, что вам нужно
Remove the four 3 mm screws from the bottom panel using a 3 mm Philips #1 screwdriver.
Use the 3 mm Philips #1 screwdriver to remove the three 3 mm screws that connect the front panel with the main underside panel. Also remove the 6 mm front panel screw.
Remove the bottom panel by pulling the plastic tabs from either side of the car.
Remove the two 6 mm screws and the two 3 mm screws that connect the back panel to the main underside panel.
Remove the two 6 mm screws that connect the rear panel to the body of the car.
Remove the two front 6 mm screws and the two middle 6 mm screws.
Remove the car shell and place it on the left side of the car.
White connection removal. Begin by removing the two 6mm Phillips #2 screws that hold down the white connection from the underside panel to the rear wheel and motor assembly.
Plastic safety cover removal. Remove plastic safety cover by removing the one 6mm Phillips #2 screw.
Desolder or cut the two wires that are connected to the motor. Use a soldering iron or wire cutters—not scissors as shown in the photo.
Remove the motor from the housing. Dislodge the left back wheel and motor assembly.
Remove the wheel hub cap with a pry tool.
Remove the wheel. Take out the one 3mm Phillips #2 screw that connects the wheel to the wheel and motor assembly
Remove the five 6mm Phillips #2 head screws from the left side of the motor housing.
Remove the two 6mm Phillips #2 screws located on either side of the small brass gear.
After removing the screws, remove motor by pulling it down and out of the housing.
Detach the black wire that is attached to the outer shell of the motor itself. Use a soldering iron or wire cutters—not scissors as shown in photo.
Using these desoldering techniques, remove the solder.
Pull apart the motor housing with care and clip off the wires that are soldered on to the motor.
Re-Solder the two wires back on to the motor when replaced. Refer to this How To Solder guide for more information.
