Xbox 360 S Top Panel Replacement
Выберете то, что вам нужно
  1. Xbox 360 S Top Panel Replacement, Top Panel: шаг 1, изображение 1 из 1
    • In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
    • Take care when removing the fan vent not to break any of the plastic clips.
  2. Xbox 360 S Top Panel Replacement: шаг 2, изображение 1 из 2 Xbox 360 S Top Panel Replacement: шаг 2, изображение 2 из 2
    • Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
    • Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
    • Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
    • Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
  3. Xbox 360 S Top Panel Replacement: шаг 3, изображение 1 из 3 Xbox 360 S Top Panel Replacement: шаг 3, изображение 2 из 3 Xbox 360 S Top Panel Replacement: шаг 3, изображение 3 из 3
    • Insert a metal spudger between the fan vent and top bezel along the left side of the console.
    • In the same manner described above, begin prying the left side of the top vent away from the top bezel.
    • Continue prying along the left side of the device, freeing all the clips on that side.
  4. Xbox 360 S Top Panel Replacement: шаг 4, изображение 1 из 2 Xbox 360 S Top Panel Replacement: шаг 4, изображение 2 из 2
    • Lift the fan vent up from the freed left side to disengage the clips along the right side.
    • Remove the entire fan vent.
  5. Xbox 360 S Top Panel Replacement: шаг 5, изображение 1 из 2 Xbox 360 S Top Panel Replacement: шаг 5, изображение 2 из 2
    • In the following steps, you will be releasing the six clips highlighted in red.
    • Each clip can be undone by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  6. Xbox 360 S Top Panel Replacement: шаг 6, изображение 1 из 2 Xbox 360 S Top Panel Replacement: шаг 6, изображение 2 из 2
    • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
    • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
    • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
    • You will hear a "pop" signifying that the clip cleared its catch.
  7. Xbox 360 S Top Panel Replacement: шаг 7, изображение 1 из 2 Xbox 360 S Top Panel Replacement: шаг 7, изображение 2 из 2
    • Using the same method described above, free the two remaining clips along the left edge of the top bezel.
  8. Xbox 360 S Top Panel Replacement: шаг 8, изображение 1 из 1
    • Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
    • You may have to go back with a spudger and undo any clips that have re-attached.
    • The top panel will not come free of the console yet.
  9. Xbox 360 S Top Panel Replacement: шаг 9, изображение 1 из 2 Xbox 360 S Top Panel Replacement: шаг 9, изображение 2 из 2
    • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
    • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
    • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
  10. Xbox 360 S Top Panel Replacement: шаг 10, изображение 1 из 2 Xbox 360 S Top Panel Replacement: шаг 10, изображение 2 из 2
    • In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
  11. Xbox 360 S Top Panel Replacement: шаг 11, изображение 1 из 1
    • Lift the top panel off the device.
    • You may have to go back with a spudger and undo any clips that have re-attached to the console.
Заключение
28 человек успешно провели ремонт по этому руководству.
Brett Hartt
Участник с: 04/12/10
131 296 Репутация
Автор 143 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 888 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 33
За последние 30 дней: 112
За всё время: 20,889
