Введение
Use this guide to replace a worn out or dead battery in your Xbox Elite Wireless Controller Series 2.
For your safety, discharge the battery below 25% before disassembling your controller. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Use your fingers to remove the thumbstick toppers.
Insert an opening tool between the left bumper and the top housing.
Pry up the top housing to release the top left clip.
Insert an opening tool into the seam between the two housings on the controller’s left edge.
Slide the opening tool along the left edge and pry up intermittently to release the plastic clips.
Insert your opening tool into the seam between the two housings on the inner left edge.
Slide the opening tool along the bottom edge and pry up intermittently to release the plastic clips.
Insert your opening tool into the seam between the two housings on the controller’s right edge.
Slide the opening tool along the right edge and pry up intermittently to release the plastic clips.
Insert your opening tool between the right bumper and the top housing.
Pry up the top housing to release the remaining plastic clips.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a Torx T8 Security screwdriver to remove the six 9 mm-long screws securing the midframe assembly.
Insert the flat end of a spudger under the top right edge of the midframe, just above the clip.
Pry up the midframe assembly to release the clips securing it.
Use a Torx T6 screwdriver to remove the four 6.9 mm-long screws securing the battery cover.
Grab the battery and lift it out of its recess.
Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
16 человек успешно провели ремонт по этому руководству.
9 Комментариев
Absolutely great tutorial, thank you. Now... any idea where I can get a replacement battery pack for this? Mine is deformed and unusable.
Hi Kraeg Minett, thanks for your comment! Unfortunately, the battery is currently not available at the iFixit Store, but you might have some luck looking for a replacement battery by either using the model code for the Elite Wireless Controller (1797) or the battery itself (DYND01).
Hello.
Great tutorial
But - i cannot find replacement battery pack ( original one )
Please - can you help me with this issue ? Thank u
Stanislav Banas
I got one here - https://kasynparts.com/product/xbox-elit...
Had it shipped to the UK and it arrived today after two weeks. I haven't yet installed it as now waiting for a T6 driver to arrive but might be worth a try.
Update - The repair was a success, the battery from the above website is good and the controller is now working again :)
