Xbox One S Case Replacement
Выберете то, что вам нужно
  1. Xbox One S Case Replacement, Case: шаг 1, изображение 1 из 1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Case Replacement: шаг 2, изображение 1 из 1
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
  3. Xbox One S Case Replacement: шаг 3, изображение 1 из 1
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Case Replacement: шаг 4, изображение 1 из 2 Xbox One S Case Replacement: шаг 4, изображение 2 из 2
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
  5. Xbox One S Case Replacement: шаг 5, изображение 1 из 2 Xbox One S Case Replacement: шаг 5, изображение 2 из 2
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield.
Заключение
42 человек успешно провели ремонт по этому руководству.
Christopher Chen
Участник с: 04/26/17
660 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S22-G3, Livingston Spring 2017 Участник Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 членов
Автор 59 руководств
5 Комментарии к руководству
I struggled with the retention tabs the first time I opened the Xbox S. I dabbed a little Armor All on a Qtip and coated both sides of tabs with a little. Popped right open the second time, wiped Armor All on the fan blades as well to minimize dust collection.
Mike DePedro - Ответить
Hi!
Great review of the process! I have a question, having stripped down an rebuilt an XBox One S to extract a 500 yuan note and two peties my 7 year old inserted in the CD/DVD slop, as well as a DOA DVD drive the power switch is not working. It works if I short the contact but there appears to be a square hole in the back of the power switch (the x box logo)
Should there be a conducting contact in the back of the switch and if so, is it simply a square lump of steel or is it tapered? Would like the dimensions please.
Many thanks for taking time to reply!
Dr B
Dr John C Bullas
Southampton UK
john.bullas - Ответить
Hi can u fit a core i5 apple gen in Xbox one s case
Aayan Beast - Ответить
Excuse me but is there an everyday item that I can use to open the bottom of my Xbox one s with?
Brody Luce - Ответить
CAUTION: Sheared off power and pairing switches when attempting to affix to panel.
Mark - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 17
За последние 7 дней: 141
За последние 30 дней: 683
За всё время: 77,727
