Введение
In this guide, you will learn how to remove the rumble motors located in the triggers. This task requires you to fully disassemble the triggers on the controller.
Выберете то, что вам нужно
Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
One you take it off, is it possible to click it back in?
As long as you don’t exceed the couple tons you need to take it off you should be able to put it back.
Brandon -
I don’t have a squdger
getting those handles back on seems impossible, they just dont fit as well, a gap remains even after snapping into place.
Dont think ill be doing this in the future
edit: wiggled the bo9ttom middlewith the handles off and somethign finally “clicked” into place for that extra 1/4 mm for the down arrow on my D-Pad to click back up into place!.
Use a screwdriver and punch a hole directly in the center of the label.
Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
It's a t8 or t9 security bit btw, I got the top two out with a regular T8, but the bottom two and middle needed a T9 Security bit.
All five faceplate/backplate screws in the controller I disassembled were T8 security fasteners.
The T8 is only good for the middle screw on my One S controller. The others require something bigger
These requires SECURITY Torx bits (they have a cannulated hole in the driver). I don't believe the iFixIt branded driver is cannulated but you can buy a set of bits from DeWalt DWAX200 which is overkill but has what you need.
The driver that iFixIt sells is cannulated.
where do you get this dumb ass screw driver
You can bypass it with a 1.5mm flathead.
thank you for this. worked for me
TR9. A $10 kit from Walmart has the bit/driver in it and extra goodies to make life simple.
As weird as it sounds, the top 2 came out for me with a flathead- but the bottom two and the middle one wont
De-solder the soldered joints while holding the red and black wires down on the top motherboard.
De-solder the black and gray wires that are attached to the top motherboard.
Remove the rumble motors and set them aside.
Steps 6-8 aren't completely necessary, and are very risky if you aren't good at soldering. It would seem the only reason to remove the motherboard and mess with all this soldering is just so you can reach both screws on the trigger in step 10. However, you can reach them already with a small-bodied screwdriver. Although you might have to rest the screwdriver on the black square processor to reach the bottom screw, it shouldn't damage the processor or motherboard to jimmy that screw out.
like mentioned by ‘Robert Rapier’ you can skip the de-soldering in most cases,
for example cleaning or changing the buttons is doable, but the grey and black wires are pretty short
and wired through the inner case so it can get a bit fiddly and you have to be careful not to damage them in the process.
If you have a soldering station around i would still recommend using it.
Unscrew the two 7mm T6 screws located near the rumble motor sockets.
Are these just T6 screws or Torx security T6 that is cannulated?
The outer screws are security screws. The ones on the system boards are Torx.
Rongwey -
Firmly grip sides of motherboard near the middle.
Lift upwards while slightly wiggling the motherboard forward and backward.
Remove the yellow tape holding the wires in place on the front of the controller.
Remove the rumble motors from its socket and pull the wire with it.
19 участников успешно повторили данное руководство.
10 Комментариев
After a drop onto tile flooring, the side clip of the outer handle snapped and got lodged into the trigger, causing it to only pull to 80% and go no further. Thanks for this breakdown.
My right trigger won't work on gta 5 and on other games it works
Very strange, Devean. That sounds more like a software problem than a hardware problem, if I had to guess. If you haven't already, maybe check to make sure that your control setup is correct.
Alternatively, see if you can find any other games that your RT doesn't work for, and see what they have in common with GTA - it might be that the trigger isn't registering as fully depressed, or only ever registering when fully depressed.
Liam Gow -
Trying to replace bumpers assembly and green sync button fell out can not figure how to put it back in.
Do you know how to remove the plastic plate where the trigger rumble sits?
Could you not just pull the wires?
How do you place the wires back onto the trigger rumble?
Where would one buy the replacement trigger motors?
can this guide be reworked to add rumble feature to the powera fusion controller for nintendo switch?
