Введение
Use this guide to remove or replace a broken rear camera glass in your Xiaomi Mi 9.
You’ll need replacement adhesive to reattach components when reassembling the device.
Выберете то, что вам нужно
Before you begin, switch off your phone.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner of the phone.
Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 9 to cut the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top left corner of the rear glass.
Slide the opening pick along the top to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right edge to cut the remaining adhesive.
Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
Insert an opening pick at the top right corner of the motherboard cover.
Twist the opening pick sideways to pry up and slightly lift the motherboard cover.
Carefully remove the motherboard cover including the charging coil / NFC antenna.
Use a spudger to pry up and disconnect the battery flex cable.
Use the flat end of a spudger to pry up and disconnect the sensor cable of the rear camera glass.
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
5 участников успешно повторили данное руководство.
Один комментарий
Hi, I need the part number of the cover with the sensors. The sensors are not working in my device.
