Введение
Follow this guide to remove the back case of your ZTE Axon 7 smartphone. You may need to remove or replace the back panel if it has become damaged or if you need to access the internals of your phone to work on other components.
In order perform this repair you'll need to use heat to loosen adhesive connecting the front and back of the phone. We suggest using the iOpener to warm up the edges of the phone before removing the back case. Please use caution as the iOpener can get hot. Use oven mitts if necessary. Do not overheat the iOpener as it can burst and potentially cause damage.
Before beginning this repair, but sure to turn off your phone and unplug it from the charger.
Выберете то, что вам нужно
Using the SIM Tray Removal Tool, press the pin into the hole on the SIM Tray (located on the top left of the device) to eject the tray.
Heat the iOpener in the microwave for 15-30 seconds.
Place the iOpener on top of the top and bottom speaker grills to loosen up the adhesive underneath.
Use a Phillips #00 screwdriver to remove the six 3 mm screws located under the speaker grills.
Carefully wedge the Jimmy between the screen and aluminum back plate of the device.
Begin near the bottom right of the device and carefully work under the screen and slide the Jimmy up the edge of the device to remove the back case.
Separate the front and back of the phone, (like a book) to open and gain access to the internal components.
Place the tip of your opening tool under the edge of the connector, and pry the connector straight up from its socket.
