Введение
If your ZTE Axon 7 phone isn't charging and you've tested the battery and the AC adapter, the charging port may need to be replaced.
Axon ZTE 7 is a reliable budget option for a quick and simple phone that needs minimal upkeep. But like most things, they need some tender love and care every now and then. Charger port restoration is a quick and simple repair. To keep the device in peak condition it is recommended that the phone be completely shut off and all accessories unplugged before beginning.
Ensure that you use light pressure whenever removing parts of the device and keep the screws/extra pieces in a neat orderly fashion to make the restoration process easier.
Выберете то, что вам нужно
Using the SIM Tray Removal Tool, press the pin into the hole on the SIM Tray (located on the top left of the device) to eject the tray.
Heat the iOpener in the microwave for 15-30 seconds.
Place the iOpener on top of the top and bottom speaker grills to loosen up the adhesive underneath.
Use a Phillips #00 screwdriver to remove the six 3 mm screws located under the speaker grills.
Carefully wedge the Jimmy between the screen and aluminum back plate of the device.
Begin near the bottom right of the device and carefully work under the screen and slide the Jimmy up the edge of the device to remove the back case.
Separate the front and back of the phone, (like a book) to open and gain access to the internal components.
Place the tip of your opening tool under the edge of the connector, and pry the connector straight up from its socket.
Use a Phillips #00 screwdriver to remove the 2.0 mm screw securing the bracket at the top of the battery.
Use the angled tweezers to slide the top bracket up and off the phone.
Place the tip of your opening tool or spudger under the edge of the battery connector, and pry the connector straight up from its socket to disconnect from the motherboard.
Use a Phillips #00 screwdriver to remove two 2.0 mm screws from the white speaker cover.
Use a Phillips #00 screwdriver to remove two 2.0 mm screws securing the bracket near the bottom of the battery, and a single 2.0 mm screw near the vibrator motor.
Use angled tweezers to remove the bottom bracket covering the main cable connector.
Pop the connector up at the bottom of the battery by placing the tip of your opening tool or spudger under the edge of the connector and prying the connector straight up from its socket.
Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial antenna cable.
Еще один человек закончил это руководство.
