Введение
Speakers can become damaged in many ways from both use and exposure to things like water. To replace these speakers requires a near full disassembly of the device but is a relatively easy process to follow through with. Follow this guide to replace the speakers of your ZTE Axon 7 smartphone.
Speakers provide sound by converting an electrical signal to sound by using magnets to vibrate a flexible cone inside of an acoustic chamber. This vibration creates the sound waves that your ears hear.
Before beginning this repair, power off your phone and make sure it's disconnected from the charger.
Выберете то, что вам нужно
Using the SIM Tray Removal Tool, press the pin into the hole on the SIM Tray (located on the top left of the device) to eject the tray.
Heat the iOpener in the microwave for 15-30 seconds.
Place the iOpener on top of the top and bottom speaker grills to loosen up the adhesive underneath.
Use a Phillips #00 screwdriver to remove the six 3 mm screws located under the speaker grills.
Carefully wedge the Jimmy between the screen and aluminum back plate of the device.
Begin near the bottom right of the device and carefully work under the screen and slide the Jimmy up the edge of the device to remove the back case.
Separate the front and back of the phone, (like a book) to open and gain access to the internal components.
Place the tip of your opening tool under the edge of the connector, and pry the connector straight up from its socket.
Use a Phillips #00 screwdriver to remove the 2.0 mm screw securing the bracket at the top of the battery.
Use the angled tweezers to slide the top bracket up and off the phone.
Place the tip of your opening tool or spudger under the edge of the battery connector, and pry the connector straight up from its socket to disconnect from the motherboard.
Use a Phillips #00 screwdriver to remove the two 2.0 mm screws securing the white speaker cover.
Place the tip of your opening tool or spudger under the edge of the two press connectors on the left side of the motherboard, and pry the connector straight up from its socket to disconnect from the motherboard.
Use a Phillips #00 screwdriver to remove the four 3.0 mm screws securing the motherboard.
