Введение
This guide has step by step instructions on how to replace your ZTE Max XL Screen Display.
Выберете то, что вам нужно
Use the SIM Card remover key, remove the SIM Card tray. To do this insert the key into the hole on the side of the phone near the SIM Card tray.
Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide
Starting at one corner, wedge a plastic opening pick or tool underneath the plastic backing to start undoing the tabs that connect the backing to the phone.
Remove the two 3.4 mm JIS #00 screws that hold the cable in place—one may be under a lock sticker.
Use a nylon spudger to lift the press-fit connector and free the ribbon cable from the main part of the phone.
Use an opening tool between the screen and side trim battery cover to remove the screen.
Use a nylon spudger to carefully lift the 6 press-fit connections free from the motherboard.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Using the iFixit opening tools carefully pry the edge of the battery away from the casing.
After taking off the battery and disconnecting all the metal tabs underneath, using the iOPener to break the adhesive between the display and the circuit.
Use the plastic opening pick in the iFixit kit to wedge between the display and circuit.
4 участников успешно повторили данное руководство.
