Введение
This guide shows how to disassemble and replace the battery within the device.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Выберете то, что вам нужно
Power off the device and keep it unplugged.
Open the case using a plastic opening tool around the edges. Slightly pull the cover.
Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each. Try to cut in the center of the two wires to solder after you replace it.
Peel off the battery from the metal casing for the LED screen. The battery will be held down with an adhesive, and it will not take much pressure to be released.
After creating space to work, warm up a soldering iron.
Apply heat onto the solder over the corresponding cut wire to the new battery wire.
Once the solder melts and forms a bridge between the two wires, try to turn on the device then check for power.
To reassemble your device, follow the initial instructions in reverse order.
Один комментарий
Where can I get a replacement battery for my jelly bean zeepad 7.0/4.2 pocket edge?
