Введение
This is a guide for replacing the motherboard of your Zeki device.
First, to reach the motherboard, remove the plastic backing, then the battery, and lastly the camera.
After replacing the motherboard, the device will need to be reassembled in the opposite order.
Выберете то, что вам нужно
Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
Place the tablet down so that the screen is facing away from you.
Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
Gently work your way around the perimeter of the tablet's edge.
Remove the back cover
Remove any tape on the speaker and detach the speaker from the back plate.
Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
2 участников успешно повторили данное руководство.
