Введение
A zipper pull is a piece of cording or ribbon that attaches to a zipper slider to make it easier to grab on to - especially while wearing mittens or gloves!
This guide will demonstrate how to attach a new pull when it has gone missing or become damaged.
Read through the entire guide before starting the repair, and gather the necessary tools and materials. While Patagonia-specific materials are ideal, they are not required. Patagonia replacement parts can be obtained by calling or messaging Patagonia Customer Service.
Alternatively, Patagonia products can be taken to a local retail store for repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
WARNING! Small Parts. Patagonia does not recommend conducting these repairs on garments intended for children age 3 or under. Instead, we recommend return of the product for professional repair services.
Выберете то, что вам нужно
Видеообзор
Zipper pull replacement overview.
If you need to remove a damaged zipper pull, skip to Step 6.
Locate the zipper slider that is missing a pull. The slider has a tab with two holes, one where the tab is attached to the slider body and one at the end of the tab.
Pinch the paracord end of the pull and slide it into the tab hole that's closer to the slider.
Pull the paracord through the tab hole.
Pinch the paracord end of the pull and thread it through the other hole on the slider tab, the one furthest from the slider body.
Thread the rubber end of the paracord pull through the loop emerging from the slider tab.
While holding the slider, pull the rubber end of the zipper pull to tighten it. The zipper pull is now inserted and should lay flat on the slider tab.
To take off a damaged zipper pull, do these same steps in reverse.
Discard the damaged pull responsibly.
6 человек успешно провели ремонт по этому руководству.
