Введение
This is where all of the power comes into the device. Learn how to replace it. Be careful while soldering!
Выберете то, что вам нужно
Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
Инструмент, используемый на этом этапе:Tweezers$4.99
Locate the three solder connections for the electrical port.
Desolder the connection points following the instructions included with your soldering kit as you remove the port.
Еще один человек закончил это руководство.
