eMac Shell Replacement
Выберете то, что вам нужно
  1. eMac Shell Replacement, Door Removal: шаг 1, изображение 1 из 3 eMac Shell Replacement, Door Removal: шаг 1, изображение 2 из 3 eMac Shell Replacement, Door Removal: шаг 1, изображение 3 из 3
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
  2. eMac Shell Replacement, Bottom Screw Removal: шаг 2, изображение 1 из 1
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
  3. eMac Shell Replacement, Top and Side Screws: шаг 3, изображение 1 из 3 eMac Shell Replacement, Top and Side Screws: шаг 3, изображение 2 из 3 eMac Shell Replacement, Top and Side Screws: шаг 3, изображение 3 из 3
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
  4. eMac Shell Replacement, Power Button Cable: шаг 4, изображение 1 из 2 eMac Shell Replacement, Power Button Cable: шаг 4, изображение 2 из 2
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
  5. eMac Shell Replacement, Shell Removal: шаг 5, изображение 1 из 1
    • Now the entire shell can be removed from the computer.
Заключение
3 участников успешно повторили данное руководство.
Chris Green
Участник с: 10/11/09
37 176 Репутация
Автор 49 руководств
Команда
Master Techs Участник Master Techs
Community
321 членов
Автор 1 514 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 24
За всё время: 2,064
