Введение
This guide will show how to install a new mother board in the iHome. For help troubleshooting click the link to our troubleshooting page iHome IH11 Troubleshooting.
Выберете то, что вам нужно
Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
Remove the translucent bottom case.
Remove the two Phillips #1 9.0mm screws on the back of the iHome.
Repeat the previous step for the two 9.0mm screws on the bottom.
Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
Pull the bracket out.
Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver.
Slide the motherboard gently out.
Еще один человек закончил это руководство.
