Введение
Use this guide to replace the adhesive on your iPad 3 4G to seal the deal on a repair job well done.
Before you begin peeling and sticking tape, it's important to have clean adhesion surfaces on both the front panel and the rear case. Use a spudger to scrape off any large excess bits of original adhesive, then clean all of the gluing surfaces with a paper towel and rubbing alcohol or Goof Off.
It is recommended that you peel each adhesive strip as needed, rather than lay them out all at once.
Выберете то, что вам нужно
Carefully grasp the home button with a pair of tweezers.
Gently lower and place the home button into the round opening located at the bottom of the front panel.
Carefully peel off the first trapezoidal adhesive strip.
Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
Lift and peel the brown backing up off the adhesive strip, revealing the clear adhesive strip.
Place the largest L-shaped adhesive strip on the top left corner of the front panel.
Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
Place the thinnest L-shaped adhesive strip on the bottom left corner of the front panel.
Place the remaining thin L-shaped adhesive strip on the top right corner of the front panel, near the camera mounting bracket.
Place the straight adhesive strip on the right side of the front panel.
If you've already attached the digitizer cable, you'll have to work around/under it to attach this strip.
Place the last L-shaped adhesive strip on the bottom right corner of the front panel.
Lay the thin T-shaped adhesive strip between the bottom edge of the inner frame of the front panel and the camera mounting bracket. The longest edge should be flush with the inner frame.
Place the small hook-shaped adhesive strip below the left side of the home button mounting bracket.
Lay the final small rectangular adhesive strip to the left of the hook-shaped adhesive strip, immediately to the right of the thin L-shaped strip, and flush with the bottom of the front panel.
4 участников успешно повторили данное руководство.
Один комментарий
Need to update this instruction because the new adhesive strips I used for my iPad3 4G repair was different than what is shown in this guide. Granted, it’s pretty easy to figure out.
