Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Carefully peel off the first trapezoidal adhesive strip with a pair of tweezers.
Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
Lift and peel the clear backing up off the adhesive strip, revealing the black adhesive strip.
Gently place the home button mounting bracket on top of the home button.
In the following steps, you will be placing the remaining pieces of adhesive on the front panel.
Do not peel the clear backing off the strips just yet.
Place the bridge shaped adhesive strip between the top edge of the inner frame of the front panel and the camera mounting bracket.
Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
Place the elongated C shaped adhesive strip on the right side of the front panel.
Place the straight, medium length adhesive strip on the bottom right side of the front panel, underneath the home button ribbon cable.
Place the tabbed rectangular adhesive strip on the bottom right side of the front panel.
Place the long L-shaped adhesive strip on the bottom left corner of the front panel.
Place the short rectangular shaped adhesive strip on the top left side of the front panel.
Place the last, short L-shaped adhesive strip on the top left corner of the front panel.
Use a pair of tweezers to peel the clear backing up off the adhesive strip directly underneath the home button ribbon cable.
Lay the home button ribbon cable down on the adhesive strip and smooth the cable down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
Use a dry microfiber cloth to clean the LCD and inside of the front panel glass. You may want to use canned air or an air compressor to blow away and dust.
Use a pair of tweezers to peel the clear backing up off each adhesive strip.
5 участников успешно повторили данное руководство.
