Введение
In this replacement of the charging port, we can see the steps needed clearly, as well as how we also need to put things back in place to make the iPhone 11 work properly. I think this repair is really important for people to know about because this issue is quite common. Having a way to solve it by yourself and not spending money on the repair would be good for people to know. In this replacement, there is not a lot of hazard present, but I think you require some basic knowledge of technology to avoid getting confused.
Выберете то, что вам нужно
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Инструмент, используемый на этом этапе:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
Insert your pick into the top-right corner of the phone.
Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
Slide the pick to the top left corner and cut any remaining adhesive securing the display.
Pull the small nub on the suction cup to detach it from the front panel.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Prop the display up against something sturdy.
Remove the 3 Y000 screws, then use a plastic spudger to disconnect the battery flex.
Unscrew the five Y000 screws securing the main logic board shield, then remove the shield
Disconnect the two display cables
Remove the three Philips screws securing the Taptic Engine
Two 1.8mm screws
One 1.9mm screw
Remove the bracket covering the Taptic Engine flex connector
Pry up on the connector to disconnect the cable from its socket
Remove the Taptic Engine
Еще один человек закончил это руководство.
2 Комментариев
Ummm, is it just me, or is he skipping a lot of steps after removing the screen? Lmao
Yes. Use this video for a complete guide:
