Введение
Use this guide to remove all components from the rear case of your iPhone 11. This guide will show you how to remove speaker, cables, taptic engine, battery, logic board, and button covers so you can replace a dented or bent cover.
Выберете то, что вам нужно
Видеоинструкции
50 человек успешно провели ремонт по этому руководству.
14 Комментариев
I really wish you had shown the size and kind of each screw and standoff.
I’m pretty sure I must have mixed them up a bit and now the screen doesn’t work.
A pic by pic instead of a video would have been awesome.
Kim Mace - Ответить
When you replace parts you always need to organize your screws the exact way you remove them… Mixing up screws will damage the motherboard. This goes for any repair.
Mason Miller -
So I've had an issue with a few iPhone 11 re-body jobs I've done. Out of about 30 that I've performed, two of them end up with an issue where the phone reboots randomly ever 2-5 minutes. (I've had to replace the phones outright for the customer.) It's not common but it is VERY frustrating.
Any idea what could be causing this?
TehachaScreens - Ответить
I myself have had this problem with a couple of iPhone XS Max’s. I’ve done many but those two had the exact same issue and I would love to know why. I hope someone answers this question. Good luck
Neil Borne -
Go to settings>Privacy & Security>Analytics & Improvements. Analytics Data: Look for Panic file. Search through this, my guess is it will show Missing sensor(s): mic2. You can Google this as well and it will tell you the potential faults.
Chris Halliwell -
The problem you've mentioned is called "boot loop". I think that while the back housing was broken some water came in and inflicted some corrosion to the flood illuminator (or the other parts) of the Face ID. Due to this, the Face ID doesn't work properly and causes the reboot. There ist this Malaysian guy who explains it, just type in on YT the words "iPhone Service Malaysia" and "boot loop", and you'll find an explanation. In addition, you can check out another video by typing in the words "fixd repair" "iphone boot loop".
KingBia -
You forgot all the upper pieces to remove?!?
Alexandre - Ответить
Na montagem da placa, percebi que o nfc não foi conectado.
Edson Alves - Ответить
HI,
Do you not connect the wireless charger coil to the logic board?
Many Thanks
Adam Lees - Ответить
Super tutoriel !
Et bravo pour les instructions de remontage , c'est loin d'être inutile .
2 petits détails à vérifier avant de recoller la batterie:
Bien controler son positionnement vertical et latéral.
Car posée trop haut, impossible de rebrancher le connecteur !
et il faut la coller contre le flanc gauche, le long des boutons de volume, car il y a une petite plaque plastique derrière ces boutons, qui se détache à force de presser les boutons... la batterie bien collée empêche cela
Merci et la vidéo complète bien les explications photos, très précieuses pour la description exacte des types de vis
Vincent Morault - Ответить
This is a great tutorial and all but it looks like the case in the affiliate link is not even the right part as your looking for a housing. All you get from the ebay in the affiliate link is just rear case glass. Im kinda !#^&@@ now as i probably will have to remove more parts making it an even harder process with a higher chance of damaging something altogether. Broke college kid getting screwed by this kinda stuff and I can't exactly afford a brand new phone if this gets damaged. Wish me luck ig and if this doesn't work I'll let everyone in the comments know.
Deon Teriyaki - Ответить
I'm curious on how and what you used to get the back glass to stay? What adhesive did you use is any?
Gene Bailey - Ответить
If you're asking about re-attaching the screen, we sell Display Assembly Adhesive for the iPhone 11. We also carry iPhone 11 Rear Cover Adhesive.
Amber Taus -
the link for the rear case ends up showing silicone cases. cant find any rear glass at all.
micke - Ответить
