Введение
Reassembly steps to install the Taptic Engine in the iPhone 16 Pro.
Выберете то, что вам нужно
Use blunt-nose tweezers or your fingers to align the Taptic Engine with its screw posts and place it in the frame.
Use a Phillips screwdriver to install the 1.9 mm‑long screw securing the Taptic Engine, located on its right edge.
Use your finger or a spudger to connect the two lower assembly press connectors.
Use a tri-point Y000 screwdriver to install the 1.0 mm‑long screw securing the lower assembly cable.
Use your finger or a spudger to connect the lower assembly cable press connector, located in the bottom-right corner of the logic board.
Use tweezers or your fingers to install the Taptic Engine cover.
Use a Phillips screwdriver to install the three screws securing the Taptic Engine cover:
One 3.0 mm‑long screw
Two 1.7 mm‑long screws
